跳转到主内容
JD Razor 2000 Back Wheel Replacement
你所需要的
  1. JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: 步骤 1 中的图像 1,2 JD Razor 2000 Back Wheel Replacement, Unscrewing the Axle Bolt: 步骤 1 中的图像 2,2
    • Facing the wheelie bar as shown, place your left thumb on the bolt located on the left side of the back wheel and place the Allen wrench into the screw on the right side of the back wheel.
    • Using the wrench, slowly unscrew the bolt while applying constant pressure from the left side.
  2. JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: 步骤 2 中的图像 1,2 JD Razor 2000 Back Wheel Replacement, Removing the Bolt and Bearing: 步骤 2 中的图像 2,2
    • Remove the bolt from the right side and the bearing from the left.
  3. JD Razor 2000 Back Wheel Replacement, Removing the Wheel: 步骤 3 中的图像 1,1
    • Turn the JD Razor 2000 on its side as shown. Slowly remove the back wheel by pulling it out at a perpendicular angle to the scooter base.
结论
Eric Johnson
于10/17/14注册
311 声望
撰写一个指南
团队
Cal Poly, Team 4-46, Amido Fall 2014 Cal Poly, Team 4-46, Amido Fall 2014 的会员
CPSU-AMIDO-F14S4G46
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 1,035
