跳转到主内容
JBL Xtreme battery replacement
你所需要的
  1. JBL Xtreme battery replacement, Battery: 步骤 1 中的图像 1,1
    • 8.4 V battery pack for the JBL Extreme.
  2. JBL Xtreme battery replacement: 步骤 2 中的图像 1,1
    • Unscrew the screws and decover the shell.
  3. JBL Xtreme battery replacement: 步骤 3 中的图像 1,1
    • Remove the battery pack by unscrewing the 8 screws. Unplug the battery pack. Drill a hole. Seal holes with hot glue because of air tightness.
  4. JBL Xtreme battery replacement: 步骤 4 中的图像 1,2 JBL Xtreme battery replacement: 步骤 4 中的图像 2,2
    • Solder up the connectors + and - . Use a DC hollow bush 5.5 x 2.1 for the current supply. Isolate the ends of the cables.
  5. JBL Xtreme battery replacement: 步骤 5 中的图像 1,1
    • Battery 8,4 Volt. 13200mAh 8,4V Rechargeable Battery Pack Charger for Bicycle Light-XML-T6
  6. JBL Xtreme battery replacement: 步骤 6 中的图像 1,1
    • Solarstorm 2S2P 18650 Battery Case.
    • 4xPanasonic NCR18650B 3,7V 3400mAh=14400 mAh
    • + 5V USB ON/OFF Button
结论
2等其他人完成本指南。
由衷感谢以下译者:
de en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Bert
于06/27/17注册
217 声望
撰写一个指南
6条评论
hi
step 2: unscrew the screws …. thats th point, where are the screws. the body looks like glued.
stephan dingsda - 回复
Hi.
Don’t ask me, because I have this guide only translated not created. Try to contact the author on de.ifixit.com. I have translated it so, that I tried to don’t change the original text.
Martin
Martin Kubica - 回复
I didn’t get it quite clear: is there a original battery replacement or an improvised one? I am interested in replacing mine but I didn’t find the battery.
Chris Fotu - 回复
Hi.
See the comment higher.
Martin Kubica
Martin Kubica - 回复
WTF?!? Don’t do this. Buy a replacement battery online, and swap it out. Don’t drill holes, add glue, and try to cram in some battery that isn’t built for it!
fixit4 - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 52
过去 30 天: 210
总计 26,441
