跳转到主内容
JBL Xtreme Speaker Replacement
你所需要的
  1. JBL Xtreme Speaker Replacement, Cover: 步骤 1 中的图像 1,1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Speaker Replacement: 步骤 2 中的图像 1,2 JBL Xtreme Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Speaker Replacement: 步骤 3 中的图像 1,2 JBL Xtreme Speaker Replacement: 步骤 3 中的图像 2,2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
  4. JBL Xtreme Speaker Replacement, Bass Radiator: 步骤 4 中的图像 1,3 JBL Xtreme Speaker Replacement, Bass Radiator: 步骤 4 中的图像 2,3 JBL Xtreme Speaker Replacement, Bass Radiator: 步骤 4 中的图像 3,3
    • Unscrew the six 9.75mm Phillips head screws holding the bass radiator in place.
    • Three of the five outer screws are indicated in the first image and the sixth inner screw is indicated in the second image.
  5. JBL Xtreme Speaker Replacement: 步骤 5 中的图像 1,3 JBL Xtreme Speaker Replacement: 步骤 5 中的图像 2,3 JBL Xtreme Speaker Replacement: 步骤 5 中的图像 3,3
    • Once the screws have been removed, the bass radiator will easily lift free.
    • Both radiators are identical. Repeat the above steps on the opposite radiator if necessary.
  6. JBL Xtreme Speaker Replacement, Speaker: 步骤 6 中的图像 1,2 JBL Xtreme Speaker Replacement, Speaker: 步骤 6 中的图像 2,2
    • With the radiators removed, locate the ribbon cable indicated in the image.
    • Gently unplug the cable from the motherbord.
  7. JBL Xtreme Speaker Replacement: 步骤 7 中的图像 1,3 JBL Xtreme Speaker Replacement: 步骤 7 中的图像 2,3 JBL Xtreme Speaker Replacement: 步骤 7 中的图像 3,3
    • First, unscrew the eight 12.93mm Phillips head screws indicated in red. These screws hold the two primary speakers in place.
    • Next, remove the four 9.75mm Phillips head screws for the two smaller speakers indicated in blue and the speakers should lift out with little effort.
    • All speakers are connected via the single cable highlighted in the previous step.
结论
15等其他人完成本指南。
Benny Huynh
于02/15/17注册
1,929 声望
创作了4篇指南
团队
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G1
4 名成员
创作了27篇指南
11条评论
My speaker won't hold a charge for more then 2 hours? Why is that thanks
Gil Trujillo - 回复
where can i buy the speaker of jbl xtreme?
Jeff Cancino - 回复
Where can I get replacement speakers for my JBL?
Luis Baca - 回复
Where can I get s replacement speaker
etesme -
where can I get parts to fix the speaker?
Dave - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 41
过去 30 天: 155
总计 29,810
