跳转到主内容
JBL Xtreme Cover Disassembly
你所需要的
  1. JBL Xtreme Cover Disassembly, Cover: 步骤 1 中的图像 1,1
    • Locate the seams next to the 'feet' on the bottom side of the device.
  2. JBL Xtreme Cover Disassembly: 步骤 2 中的图像 1,2 JBL Xtreme Cover Disassembly: 步骤 2 中的图像 2,2
    • Use the metal spudger to gently pry and lift the edge of the seam. The cover is held in place with plastic snaps that will make a popping noise when disengaged. !!Start with the back half, this will expose TWO Screws that need to be removed before lifting the front half.
  3. JBL Xtreme Cover Disassembly: 步骤 3 中的图像 1,2 JBL Xtreme Cover Disassembly: 步骤 3 中的图像 2,2
    • For the first part of the case: gently pull back the edges of the case rotating along the hinge opposite the opening seam illustrated in the second photo. Plastic snaps hold the cover in place.
    • For the second part of the case: there are 2 screws to be removed at the seam. Once removed, the case will come off completely without forcing.
结论
14等其他人完成本指南。
Benny Huynh
于02/15/17注册
1,929 声望
创作了4篇指南
团队
USF Tampa, Team 1-1, Sullivan Spring 2017 USF Tampa, Team 1-1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S1G1
4 名成员
创作了27篇指南
5条评论
Can you fix my cover on speaker
c_pg08 - 回复
where can I find a new cover for xtreme 2, if possible in black?
vale0501 - 回复
If you find a place to buy a cover let me know
abjayaman -
you forgot about 2 screws
Enescu Catalin - 回复
zapomniałeś o śrubach osoby które o tym mogły nie wiedzieć mogły urwać plastikowy haczyk który utrzymuje przód
megakacper11 - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 42
过去 30 天: 181
总计 30,399
