跳转到主内容
JBL Xtreme 3 Battery Replacement
你所需要的
  1. JBL Xtreme 3 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Begin by placing the speaker with the grooves on the bottom of the device facing towards you.
    • Use a spudger to carefully pry around the seams of the speaker to open and unlatch the outer shell.
    • Use your hands to finish removing the outer case of the device.
  2. JBL Xtreme 3 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two 10 mm screws.
  3. JBL Xtreme 3 Battery Replacement: 步骤 3 中的图像 1,2 JBL Xtreme 3 Battery Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to carefully pry open the latch located above the control button as shown in the photo. Please be careful!!!
    • Remove the speaker from the shell.
  4. JBL Xtreme 3 Battery Replacement: 步骤 4 中的图像 1,2 JBL Xtreme 3 Battery Replacement: 步骤 4 中的图像 2,2
    • Turn the device so that the control buttons are facing down.
    • Use a Phillips #1 screwdriver to remove the eight 10 mm screws from the panel.
    • Carefully remove the panel.
  5. JBL Xtreme 3 Battery Replacement: 步骤 5 中的图像 1,2 JBL Xtreme 3 Battery Replacement: 步骤 5 中的图像 2,2
    • The battery is connected to a cable. Use gentle force.
    • Use the spudger to carefully pry the battery out.
  6. JBL Xtreme 3 Battery Replacement: 步骤 6 中的图像 1,3 JBL Xtreme 3 Battery Replacement: 步骤 6 中的图像 2,3 JBL Xtreme 3 Battery Replacement: 步骤 6 中的图像 3,3
    • Use the plastic opening tool to press the white notch while simultaneously unplugging the battery connector.
    • Plug in the replacement.
    • Make sure the new battery is secure. Turn on the device to ensure that the battery is connected properly.
结论
5等其他人完成本指南。
一条评论
Great guide! Thank you!
dam damo - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 45
过去 30 天: 193
总计 2,487
