跳转到主内容
JBL Tune 710BT Ear Pad Cushion Replacement
你所需要的
  1. JBL Tune 710BT Ear Pad Cushion Replacement, Ear Pad Cushion: 步骤 1 中的图像 1,1
    • Gently grasp the edge of the ear cushion and pull it away from the earcup.
    • The cushion is usually snapped or clipped into place and should come off with moderate force. If the cushions are glued, carefully pry them away from the earcup, either with hands or gently with a tool.
  2. JBL Tune 710BT Ear Pad Cushion Replacement: 步骤 2 中的图像 1,1
    • Align the new ear cushion with the earcup.
    • There should be notches or tabs that align with corresponding slots on the earcup.
    • Press the cushion into place, ensuring that it is securely fastened all around the earcup.
    • Once attached, gently pull around the edges of the cushion to ensure it is securely fastened and there are no loose parts.
结论
With the new ear cushions installed, your JBL Tune 710BT headphones should feel more comfortable and provide better sound isolation. This simple upgrade can significantly enhance your audio experience.
Amber Hooda
于03/18/24注册
90 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-1, Konn Spring 2024 UMass Dartmouth, Team 2-1, Konn Spring 2024 的会员
UMASSD-KONN-S24S2G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 21
过去 30 天: 21
总计 36
