跳转到主内容
JBL Spyro/Spot Partial Disassembly
你所需要的
  1. JBL Spyro/Spot Partial Disassembly, Locate the risers: 步骤 1 中的图像 1,1
    • Locate the 3 risers the hold the base plate in place
  2. JBL Spyro/Spot Partial Disassembly, Pry the plugs from the risers: 步骤 2 中的图像 1,1
    • Insert a strong spudger or flathead near the riser and gently pry until the plug starts to come out. Work your way around to loosening each one.
  3. JBL Spyro/Spot Partial Disassembly, Remove the base plate: 步骤 3 中的图像 1,1
    • With all three loosened remove the base!
    • Note the not equilateral placement of the risers when replacing the base.
结论
17等其他人完成本指南。
Ryan McLeod
于05/22/10注册
606 声望
创作了2篇指南
11条评论
Thanks, so nice tip. I'll see if I can find a similar speaker, big hug.
durval - 回复
My speaker is broken like on the image above and it sounds horrible. Do you know where to buy similar speaker in order to replice it?
pszopa - 回复
Does anybody know, if I can get a replacement speaker for the subwoofer of the JBL 2.1. system? Thanks!
Lars -
I was unable to find a replacement for the Atlas subwoofer it uses and ended up "recycling" the whole thing :( I've since replaced it with the the Klipsch ProMedia 2.1s and love them.
Ryan McLeod -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 75
总计 12,977
