跳转到主内容
JBL Pulse Speakers Replacement
你所需要的
  1. JBL Pulse Speakers Replacement, Button Board: 步骤 1 中的图像 1,1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Speakers Replacement: 步骤 2 中的图像 1,1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Speakers Replacement: 步骤 3 中的图像 1,1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Speakers Replacement: 步骤 4 中的图像 1,1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Speakers Replacement: 步骤 5 中的图像 1,1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Speakers Replacement, Outer Casing: 步骤 6 中的图像 1,3 JBL Pulse Speakers Replacement, Outer Casing: 步骤 6 中的图像 2,3 JBL Pulse Speakers Replacement, Outer Casing: 步骤 6 中的图像 3,3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: 步骤 7 中的图像 1,2 JBL Pulse Speakers Replacement, JBL Pulse LED Lights Disassembly: 步骤 7 中的图像 2,2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Speakers Replacement, JBL Pulse Disassembly: 步骤 8 中的图像 1,1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Speakers Replacement: 步骤 9 中的图像 1,3 JBL Pulse Speakers Replacement: 步骤 9 中的图像 2,3 JBL Pulse Speakers Replacement: 步骤 9 中的图像 3,3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Speakers Replacement: 步骤 10 中的图像 1,2 JBL Pulse Speakers Replacement: 步骤 10 中的图像 2,2
    • Remove cables by pulling firmly.
  11. JBL Pulse Speakers Replacement, Speakers: 步骤 11 中的图像 1,2 JBL Pulse Speakers Replacement, Speakers: 步骤 11 中的图像 2,2
    • Remove four black PH0 9mm screws.
    • The only thing still attaching the speakers is the wires to the soldering points. Cut wires at soldering points.
    • New speakers will have to be re-soldered to these wires.
结论
6等其他人完成本指南。
团队
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G6
3 名成员
创作了8篇指南
8条评论
Hi,
Thanks for your guide. Where did you obtain replacement speakers?
heaton.steven - 回复
Hi. Even I would like to know a good replacement/ substitute speaker for this. Thanks
Vishakh A V - 回复
Hi.
Even I would like to know where I can find a replacement or an alternate speaker..
Vishakh A V - 回复
what is the speaker specification that I can buy for replacement?
rbalagr - 回复
Could you please share any links to buy these spare speakers ..Thanks in advance ☺️
deepak gupta - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 54
总计 7,357
