跳转到主内容
JBL Pulse Motherboard Replacement
你所需要的
  1. JBL Pulse Motherboard Replacement, Button Board: 步骤 1 中的图像 1,1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Motherboard Replacement: 步骤 2 中的图像 1,1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Motherboard Replacement: 步骤 4 中的图像 1,1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Motherboard Replacement: 步骤 5 中的图像 1,1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Motherboard Replacement, Outer Casing: 步骤 6 中的图像 1,3 JBL Pulse Motherboard Replacement, Outer Casing: 步骤 6 中的图像 2,3 JBL Pulse Motherboard Replacement, Outer Casing: 步骤 6 中的图像 3,3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: 步骤 7 中的图像 1,2 JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: 步骤 7 中的图像 2,2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: 步骤 8 中的图像 1,1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Motherboard Replacement: 步骤 9 中的图像 1,3 JBL Pulse Motherboard Replacement: 步骤 9 中的图像 2,3 JBL Pulse Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Motherboard Replacement: 步骤 10 中的图像 1,2 JBL Pulse Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove cables by pulling firmly.
  11. JBL Pulse Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Once all of the cables are removed, grip the motherboard and slide it out.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G6
3 名成员
创作了8篇指南
3条评论
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - 回复
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - 回复
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 9,366
