跳转到主内容
JBL Pulse LED Light Replacement
你所需要的
  1. JBL Pulse LED Light Replacement, Button Board: 步骤 1 中的图像 1,1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse LED Light Replacement: 步骤 2 中的图像 1,1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse LED Light Replacement: 步骤 3 中的图像 1,1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse LED Light Replacement: 步骤 4 中的图像 1,1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse LED Light Replacement: 步骤 5 中的图像 1,1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse LED Light Replacement, Outer Casing: 步骤 6 中的图像 1,3 JBL Pulse LED Light Replacement, Outer Casing: 步骤 6 中的图像 2,3 JBL Pulse LED Light Replacement, Outer Casing: 步骤 6 中的图像 3,3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: 步骤 7 中的图像 1,2 JBL Pulse LED Light Replacement, JBL Pulse LED Lights Disassembly: 步骤 7 中的图像 2,2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse LED Light Replacement, LED Light: 步骤 8 中的图像 1,1
    • Pry off LED light panel using a metal spudger.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 18-6, Blackwell Fall 2016 USF Tampa, Team 18-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S18G6
3 名成员
创作了8篇指南
一条评论
Were do I buy a Replacement led strip?
Jalen6988 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 3,406
