跳转到主内容
JBL Pulse 4 Outside Casing Replacement
你所需要的
  1. JBL Pulse 4 Outside Casing Replacement, Casing Replacement: 步骤 1 中的图像 1,1
    • Power on JBL speaker before doing any repairs.
    • Hold the power button for 3+ seconds to power down the device.
  2. JBL Pulse 4 Outside Casing Replacement: 步骤 2 中的图像 1,3 JBL Pulse 4 Outside Casing Replacement: 步骤 2 中的图像 2,3 JBL Pulse 4 Outside Casing Replacement: 步骤 2 中的图像 3,3
    • Remove each rubber end cap using a plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap until there is a gap on all sides.
    • Remove the top by hand.
  3. JBL Pulse 4 Outside Casing Replacement: 步骤 3 中的图像 1,3 JBL Pulse 4 Outside Casing Replacement: 步骤 3 中的图像 2,3 JBL Pulse 4 Outside Casing Replacement: 步骤 3 中的图像 3,3
    • Remove the charging port cover using a plastic pry tool.
    • Remove the two 12.7 mm Phillips #1 screws.
    • Remove the charging port housing from the casing.
  4. JBL Pulse 4 Outside Casing Replacement: 步骤 4 中的图像 1,3 JBL Pulse 4 Outside Casing Replacement: 步骤 4 中的图像 2,3 JBL Pulse 4 Outside Casing Replacement: 步骤 4 中的图像 3,3
    • Disconnect the charging port connector by pulling the connector away from the port.
    • Disconnect the battery level indicator light by pulling the wire away from the lights.
  5. JBL Pulse 4 Outside Casing Replacement: 步骤 5 中的图像 1,2 JBL Pulse 4 Outside Casing Replacement: 步骤 5 中的图像 2,2
    • Remove the six 8 mm Phillips #1 screws from the end of the speaker with the grill that says "JBL."
    • Remove the plastic piece where the 6 screws came out of.
  6. JBL Pulse 4 Outside Casing Replacement: 步骤 6 中的图像 1,1
    • Remove the six 9.5 mm screws using a Phillips #1 screwdriver.
  7. JBL Pulse 4 Outside Casing Replacement: 步骤 7 中的图像 1,3 JBL Pulse 4 Outside Casing Replacement: 步骤 7 中的图像 2,3 JBL Pulse 4 Outside Casing Replacement: 步骤 7 中的图像 3,3
    • Flip the speaker to the other end.
    • Use a pry tool to pry between the casing of the speaker and the internals.
    • Go around the entirety of this end of the speaker slowly prying apart the two pieces.
  8. JBL Pulse 4 Outside Casing Replacement: 步骤 8 中的图像 1,1
    • The casing is now fully detached from the internal components.
    • You can now replace the outer casing of the speaker.
结论
Hank McDonough
于03/18/24注册
377 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-2, Konn Spring 2024 UMass Dartmouth, Team 2-2, Konn Spring 2024 的会员
UMASSD-KONN-S24S2G2
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 37
总计 97
