跳转到主内容
JBL Pulse 4 Charging Port Replacement
你所需要的
  1. JBL Pulse 4 Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Power off JBL Pulse 4 before starting any repairs.
    • Hold the power button for 3 plus seconds to power down the device.
  2. JBL Pulse 4 Charging Port Replacement: 步骤 2 中的图像 1,3 JBL Pulse 4 Charging Port Replacement: 步骤 2 中的图像 2,3 JBL Pulse 4 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Remove each rubber end cap using an plastic pry tool.
    • Go around each end of the speaker slowly popping up a small section of the rubber cap at a time until there is a gap on all sides.
    • The cap can be easily removed by hand.
    • Do not use a metal object or you will scratch the casing or tear the rubber end caps.
  3. JBL Pulse 4 Charging Port Replacement: 步骤 3 中的图像 1,3 JBL Pulse 4 Charging Port Replacement: 步骤 3 中的图像 2,3 JBL Pulse 4 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Carefully remove the charging port cover using a plastic pry tool.
    • Remove the two Phillips head screws.
    • The charging port assembly will be revealed.
  4. JBL Pulse 4 Charging Port Replacement: 步骤 4 中的图像 1,3 JBL Pulse 4 Charging Port Replacement: 步骤 4 中的图像 2,3 JBL Pulse 4 Charging Port Replacement: 步骤 4 中的图像 3,3
    • Pull the charging port assembly out of the casing.
    • Be careful and don't remove the assembly fully to avoid damaging the wires.
    • Carefully disconnect the two wires attached to the assembly.
  5. JBL Pulse 4 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Now you can reassemble the speaker reversing the steps provided to take it apart.
结论
Hank McDonough
于03/18/24注册
377 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-2, Konn Spring 2024 UMass Dartmouth, Team 2-2, Konn Spring 2024 的会员
UMASSD-KONN-S24S2G2
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 29
总计 64
