跳转到主内容
JBL Pulse 3 Charging Port Replacement
你所需要的
  1. JBL Pulse 3 Charging Port Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 Charging Port Replacement: 步骤 3 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 3 中的图像 2,2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 Charging Port Replacement, Outside Casing: 步骤 5 中的图像 1,2 JBL Pulse 3 Charging Port Replacement, Outside Casing: 步骤 5 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
  5. JBL Pulse 3 Charging Port Replacement: 步骤 6 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 6 中的图像 2,2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
  6. JBL Pulse 3 Charging Port Replacement: 步骤 7 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 7 中的图像 2,2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 Charging Port Replacement: 步骤 8 中的图像 1,1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 Charging Port Replacement: 步骤 9 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 9 中的图像 2,2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
  9. JBL Pulse 3 Charging Port Replacement: 步骤 10 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 10 中的图像 2,2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 Charging Port Replacement: 步骤 11 中的图像 1,1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 Charging Port Replacement, LED Light Display: 步骤 12 中的图像 1,3 JBL Pulse 3 Charging Port Replacement, LED Light Display: 步骤 12 中的图像 2,3 JBL Pulse 3 Charging Port Replacement, LED Light Display: 步骤 12 中的图像 3,3
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 Charging Port Replacement: 步骤 13 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to pull the five connections off of the LED light display.
  13. JBL Pulse 3 Charging Port Replacement, Motherboard: 步骤 14 中的图像 1,2 JBL Pulse 3 Charging Port Replacement, Motherboard: 步骤 14 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the two black 8mm screws on the bottom of the LED light display.
  14. JBL Pulse 3 Charging Port Replacement: 步骤 15 中的图像 1,3 JBL Pulse 3 Charging Port Replacement: 步骤 15 中的图像 2,3 JBL Pulse 3 Charging Port Replacement: 步骤 15 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Pull out the motherboard slightly from the LED light display as shown. Using tweezers, unplug the three connections attached to the motherboard.
  15. JBL Pulse 3 Charging Port Replacement: 步骤 16 中的图像 1,1
    • Pull the rest of the motherboard out from the LED light display.
    • Using wire cutters, snip the black wire connecting to the base of the JBL Pulse 3 at the base of the motherboard. The motherboard should now be removed from the JBL Pulse 3.
  16. JBL Pulse 3 Charging Port Replacement, Speaker: 步骤 17 中的图像 1,2 JBL Pulse 3 Charging Port Replacement, Speaker: 步骤 17 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the four 10mm screws on the corner of the speaker on the side of the base of the JBL Pulse 3.
  17. JBL Pulse 3 Charging Port Replacement: 步骤 18 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 18 中的图像 2,2
    • Pull out the speaker and cut the black and red wire with wire cutters. The speaker should now be removed from the JBL Pulse 3.
  18. JBL Pulse 3 Charging Port Replacement, Charging Port: 步骤 19 中的图像 1,2 JBL Pulse 3 Charging Port Replacement, Charging Port: 步骤 19 中的图像 2,2
    • Repeat the steps to take out all three speakers on the base of the JBL Pulse 3.
    • Using a Phillips #0 screwdriver, remove the 6 mm screw under each of the three speakers around the base of the JBL Pulse 3.
  19. JBL Pulse 3 Charging Port Replacement: 步骤 20 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 20 中的图像 2,2
    • Grab the outside of the JBL Pulse 3 at the bottom and pull outward until the outside button cover comes off.
  20. JBL Pulse 3 Charging Port Replacement: 步骤 21 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 21 中的图像 2,2
    • Disconnect the two connections from the inside side of the base of the JBL Pulse 3 by pushing on the wire with your index finger in the opposite direction of the connection.
  21. JBL Pulse 3 Charging Port Replacement: 步骤 22 中的图像 1,2 JBL Pulse 3 Charging Port Replacement: 步骤 22 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four 10mm screws by the push buttons on the side of the base of the JBL Pulse 3.
  22. JBL Pulse 3 Charging Port Replacement: 步骤 23 中的图像 1,1
    • Pull off the inside button cover with the attached charging port. The charging port should now be removed.
结论
5等其他人完成本指南。
3条评论
And how to put it back with cut cable?
Robert Rpunkt - 回复
I've done a teardown and was able to access the charging terminal without cutting any wires. I didn't have a replacement, so I just put it back together hoping that cleaning it would work. Didn't work.
Beresford Crowder - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 24
过去 30 天: 148
总计 16,238
