简介
If there is a problem with the audio of your JBL Pulse 2, you may need to replace the speakers. Replacing the speakers ensures that you receive the best listening quality when using your device.
你所需要的
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
2等其他人完成本指南。
