跳转到主内容
JBL Pulse 2 Button Circuit Board Replacement
你所需要的
  1. JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: 步骤 1 中的图像 1,2 JBL Pulse 2 Button Circuit Board Replacement, Button Circuit Board: 步骤 1 中的图像 2,2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Button Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Button Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Button Circuit Board Replacement: 步骤 4 中的图像 1,2 JBL Pulse 2 Button Circuit Board Replacement: 步骤 4 中的图像 2,2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Button Circuit Board Replacement: 步骤 5 中的图像 1,3 JBL Pulse 2 Button Circuit Board Replacement: 步骤 5 中的图像 2,3 JBL Pulse 2 Button Circuit Board Replacement: 步骤 5 中的图像 3,3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Button Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Button Circuit Board Replacement: 步骤 7 中的图像 1,2 JBL Pulse 2 Button Circuit Board Replacement: 步骤 7 中的图像 2,2
    • Unlatch the mechanism holding the ribbon wires in place then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Button Circuit Board Replacement: 步骤 8 中的图像 1,2 JBL Pulse 2 Button Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
结论
3等其他人完成本指南。
4指南评论
where can I buy that part
Wilco Peters - 回复
I love you guys
Davi Dodo - 回复
I need to buy parts
hernzum - 回复
How can I find the cable connecting main board and button circuit
MARK SAMUDENI - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 29
总计 1,399
