跳转到主内容
JBL Pulse 2 Battery Replacement
你所需要的
  1. JBL Pulse 2 Battery Replacement, Battery: 步骤 1 中的图像 1,2 JBL Pulse 2 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Battery Replacement: 步骤 4 中的图像 1,2 JBL Pulse 2 Battery Replacement: 步骤 4 中的图像 2,2
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Battery Replacement: 步骤 5 中的图像 1,3 JBL Pulse 2 Battery Replacement: 步骤 5 中的图像 2,3 JBL Pulse 2 Battery Replacement: 步骤 5 中的图像 3,3
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Battery Replacement: 步骤 6 中的图像 1,1
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Battery Replacement: 步骤 7 中的图像 1,2 JBL Pulse 2 Battery Replacement: 步骤 7 中的图像 2,2
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Battery Replacement: 步骤 8 中的图像 1,2 JBL Pulse 2 Battery Replacement: 步骤 8 中的图像 2,2
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Battery Replacement: 步骤 9 中的图像 1,2 JBL Pulse 2 Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Battery Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Battery Replacement: 步骤 12 中的图像 1,1
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Battery Replacement: 步骤 13 中的图像 1,2 JBL Pulse 2 Battery Replacement: 步骤 13 中的图像 2,2
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Battery Replacement: 步骤 14 中的图像 1,2 JBL Pulse 2 Battery Replacement: 步骤 14 中的图像 2,2
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Battery Replacement: 步骤 15 中的图像 1,1
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
结论
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 83
总计 7,722
