简介
If you experience any difficulties with charging or playing music through an auxiliary cable, you may need to replace your JBL Pulse 2 speaker's auxiliary and micro USB ports.
你所需要的
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
在这个步骤中使用的工具:Tweezers$3.99
Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
Remove the solder on the micro USB and Auxiliary port wires to disconnect them.
15等其他人完成本指南。
8条评论
Is there a video out there to demonstrate this repair process?
Hallo, suche für die “JBL pulse 2” die Bauteile FB5 und D9 auf dem Mainboard.
Wer kennt diese Bauteile ?
Würde mich auf eine positive Antwort freuen.
Liebe Grüße J.R.
Bonjour pourriez-vous me dire ou acheter cette petite carte électronique merci.
