跳转到主内容
JBL On Stage II Power Button Replacement
你所需要的
  1. JBL On Stage II Power Button Replacement, Cracking the Case: 步骤 1 中的图像 1,1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Power Button Replacement: 步骤 2 中的图像 1,1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Power Button Replacement: 步骤 3 中的图像 1,1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Power Button Replacement: 步骤 4 中的图像 1,2 JBL On Stage II Power Button Replacement: 步骤 4 中的图像 2,2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Power Button Replacement: 步骤 5 中的图像 1,3 JBL On Stage II Power Button Replacement: 步骤 5 中的图像 2,3 JBL On Stage II Power Button Replacement: 步骤 5 中的图像 3,3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Power Button Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Power Button Replacement: 步骤 7 中的图像 1,2 JBL On Stage II Power Button Replacement: 步骤 7 中的图像 2,2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II Power Button Replacement, Power Button: 步骤 8 中的图像 1,2 JBL On Stage II Power Button Replacement, Power Button: 步骤 8 中的图像 2,2
    • Pull the plastic button off the post.
  9. JBL On Stage II Power Button Replacement: 步骤 9 中的图像 1,1
    • Remove the metal U-clip (compressing the spring) with tweezers.
结论
团队
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G28
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,845
