跳转到主内容
JBL On Stage II 30-Pin Connector Replacement
你所需要的
  1. JBL On Stage II 30-Pin Connector Replacement, Cracking the Case: 步骤 1 中的图像 1,1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II 30-Pin Connector Replacement: 步骤 2 中的图像 1,1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II 30-Pin Connector Replacement: 步骤 3 中的图像 1,1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II 30-Pin Connector Replacement: 步骤 4 中的图像 1,2 JBL On Stage II 30-Pin Connector Replacement: 步骤 4 中的图像 2,2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II 30-Pin Connector Replacement: 步骤 5 中的图像 1,3 JBL On Stage II 30-Pin Connector Replacement: 步骤 5 中的图像 2,3 JBL On Stage II 30-Pin Connector Replacement: 步骤 5 中的图像 3,3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II 30-Pin Connector Replacement: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II 30-Pin Connector Replacement: 步骤 7 中的图像 1,2 JBL On Stage II 30-Pin Connector Replacement: 步骤 7 中的图像 2,2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    Where do I find these speakers
    HighChief - 回复
  8. JBL On Stage II 30-Pin Connector Replacement, 30-Pin Connector Replacement: 步骤 8 中的图像 1,1
    • Apply heat with a heatgun on a low setting to the area around the 30-pin connector until you can easily pry it out by the seam surrounding it (about 10 minutes).
  9. JBL On Stage II 30-Pin Connector Replacement: 步骤 9 中的图像 1,1
    • Use a metal spudger to pry out the plastic surrounding the 30-pin connector.
  10. JBL On Stage II 30-Pin Connector Replacement: 步骤 10 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to wiggle out the 30-pin connector.
结论
另外一个人完成了本指南。
团队
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G28
4 名成员
创作了7篇指南
2条评论
and how you get a new one of the 30 pin connector?
bini barazany - 回复
Yes, where can we buy a new one of the 30 pin connector?
Jimbo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 4,449
