跳转到主内容
JBL Go Woofer Replacement
你所需要的
  1. JBL Go Woofer Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
  2. JBL Go Woofer Replacement: 步骤 2 中的图像 1,1
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
  3. JBL Go Woofer Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the loose plastic cover from the speaker.
  4. JBL Go Woofer Replacement, Woofer: 步骤 4 中的图像 1,2 JBL Go Woofer Replacement, Woofer: 步骤 4 中的图像 2,2
    • Once the front cover is removed, use a T6 screwdriver head to remove the four 9 mm screws on the black cover.
  5. JBL Go Woofer Replacement: 步骤 5 中的图像 1,1
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
  6. JBL Go Woofer Replacement: 步骤 6 中的图像 1,1
    • Carefully unplug the woofer wires from the motherboard
  7. JBL Go Woofer Replacement: 步骤 7 中的图像 1,1
    • Once the black cover is fully detached from the speaker, unscrew the woofer from the back of the black cover using a T6 screwdriver head.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 30
过去 30 天: 104
总计 1,932
