跳转到主内容
JBL Go Repair Motherboard Replacement
你所需要的
  1. JBL Go Repair Motherboard Replacement, Front Cover: 步骤 1 中的图像 1,1
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
  2. JBL Go Repair Motherboard Replacement: 步骤 2 中的图像 1,1
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
  3. JBL Go Repair Motherboard Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the loose plastic cover from the speaker.
  4. JBL Go Repair Motherboard Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Once the front cover is removed, use a T6 screwdriver to remove the four 9 mm screws on the black cover.
  5. JBL Go Repair Motherboard Replacement: 步骤 5 中的图像 1,1
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
  6. JBL Go Repair Motherboard Replacement: 步骤 6 中的图像 1,1
    • Carefully unplug the woofer wires from the motherboard.
  7. JBL Go Repair Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use the T6 screwdriver to remove the 9 mm screw that secures the motherboard in place.
  8. JBL Go Repair Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift the motherboard using the plastic opening tool and stick it through the hole in the middle of the board.
  9. JBL Go Repair Motherboard Replacement: 步骤 9 中的图像 1,1
    • Carefully lift the motherboard, sliding the charging port side out of the frame of the speaker as you go.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 39
过去 30 天: 153
总计 2,944
