跳转到主内容
JBL Flip 4 Shell Replacement
你所需要的
  1. JBL Flip 4 Shell Replacement, Shell: 步骤 1 中的图像 1,3 JBL Flip 4 Shell Replacement, Shell: 步骤 1 中的图像 2,3 JBL Flip 4 Shell Replacement, Shell: 步骤 1 中的图像 3,3
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Shell Replacement: 步骤 2 中的图像 1,3 JBL Flip 4 Shell Replacement: 步骤 2 中的图像 2,3 JBL Flip 4 Shell Replacement: 步骤 2 中的图像 3,3
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
结论
8等其他人完成本指南。
Philip Pang
于10/08/18注册
1,314 声望
创作了4篇指南
团队
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 的会员
CPSU-WHITE-F18S4G3
4 名成员
创作了37篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 35
过去 30 天: 114
总计 15,002
