简介
Is your JBL Flip 4 speaker making abnormal sounds? Does the speaker sound different than when you first got it? If so, your JBL Flip 4's front action speakers may be damaged. This guide will instruct you on removing the damaged speaker so you can later replace it with a new one.
你所需要的
Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
Pry off the cover, beginning with the side without the volume and bluetooth buttons.
Pull off the cover with your thumbs.
Cut the red, white, and black wires connected to the speaker using wire cutters.
where can i find replacement speaker
Soan Soram - 回复
Die Kabel müssen abgelötet werden!
Sie haben auf der Platine auch eine Steckverbindung.
Und was nützt die beste Anleitung, wenn man die Lautsprecher nicht bekommt.
Ersatzlautsprecher habe ich bei Ebay gesehen.
14等其他人完成本指南。
16条评论
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Exactly, what is the part number for the internal speaker?
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
Why does this transducer have 3 terminals?
From what I can read it's for shielding, to reduce interference. But I also read that it would not be very effective.
Looking at the transducer, the white wire is merely connected to the chassis.
It can be omitted, so no need to find a replacement that has a shield lead.
Johankat -
Where I can find the replacement speaker
quesitosmr - 回复
I couldn’t find replacement drivers for the flip 4 so I just duck taped the driver pads, they work ok now.
It really work??
I have a Flip 4 where I just replaced the motherboard. However the wires that are attached leading up to splice with the speaker are aluminum. My speakers off the original Motherboard has copper wire. After splicing the 2 together, i checked for continuity and it was successful but i did not have any sound from the speaker. Please Help
Der Austausch ist nicht das Problem. Aber wo bekomme ich ein Ersatzteil her. Mit der Nummer psp00018001 finde ich im Netz nichts.
Ich habe erst vor kurzem Ersatzlautsprecher auf Ebay gesehen.
Where to find these speakers? Have googled but could not find any that ships to the Netherlands!
