跳转到主内容
JBL Flip 3 USB Chip Replacement
你所需要的
  1. JBL Flip 3 USB Chip Replacement, USB Chip: 步骤 1 中的图像 1,1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 USB Chip Replacement: 步骤 2 中的图像 1,1
    • Carefully remove outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 USB Chip Replacement: 步骤 3 中的图像 1,1
    • loosen the screws to remove the outer frame
  4. JBL Flip 3 USB Chip Replacement: 步骤 4 中的图像 1,1
    • Remove the 8 8.9mm Phillips #00 screws to unfasten the side passive drivers. Set the screws and side passive drivers aside safely.
  5. JBL Flip 3 USB Chip Replacement: 步骤 5 中的图像 1,1
  6. JBL Flip 3 USB Chip Replacement: 步骤 6 中的图像 1,2 JBL Flip 3 USB Chip Replacement: 步骤 6 中的图像 2,2
    • Remove the 3 pin connector from the USB chip.
  7. JBL Flip 3 USB Chip Replacement: 步骤 7 中的图像 1,1
    • remove screws to expose usb port
结论
49等其他人完成本指南。
College Student
于02/22/17注册
3,479 声望
创作了4篇指南
团队
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 的会员
USFT-LEAHY-S17S1G2
5 名成员
创作了17篇指南
21条评论
how can i find the part..email me at leedeen2000@yahoo.com plz
leedeen2000 - 回复
I feel that the difficulty is just because of the lack of detail on the instructions. I also need to find the part, but where do I get it? I searched on eBay, Amazon and got nothing. That means that I have to scavenge this part from another one?
rodri.mendoza.t - 回复
i already got step 5, but i need know how i can get the replacement ? Any idea ?
PabloM - 回复
Looking for the part 2…
Daniel Brockbank - 回复
Looking for the same thing…
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 79
过去 30 天: 293
总计 61,158
