跳转到主内容
JBL Flip 3 Power Circuit Board Replacement
你所需要的
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: 步骤 1 中的图像 1,1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Carefully remove outer housing to expose the inner components of the speaker.
  3. JBL Flip 3 Power Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
结论
14等其他人完成本指南。
James Bianco
于02/20/17注册
151 声望
撰写一个指南
团队
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 的会员
USFT-LEAHY-S17S1G2
5 名成员
创作了17篇指南
5条评论
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - 回复
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - 回复
The title says replacement, and you show only the removal.
Stanimir Nikolov - 回复
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - 回复
Change the battery
odii Emmanuel -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 40
过去 30 天: 214
总计 30,402
