跳转到主内容
JBL Everest Elite 300 Headband Cushion Replacement
你所需要的
  1. JBL Everest Elite 300 Headband Cushion Replacement, Headband Cushion: 步骤 1 中的图像 1,1
    • Extend the headphone.
  2. JBL Everest Elite 300 Headband Cushion Replacement: 步骤 2 中的图像 1,3 JBL Everest Elite 300 Headband Cushion Replacement: 步骤 2 中的图像 2,3 JBL Everest Elite 300 Headband Cushion Replacement: 步骤 2 中的图像 3,3
    • Bend the hinge slightly, then remove the two .5 mm screws with a Phillips #000 screwdriver.
    • This will be repeated on both sides.
  3. JBL Everest Elite 300 Headband Cushion Replacement: 步骤 3 中的图像 1,1
    • Slide down the "Elite 300" tab.
    • Repeat on both sides.
  4. JBL Everest Elite 300 Headband Cushion Replacement: 步骤 4 中的图像 1,2 JBL Everest Elite 300 Headband Cushion Replacement: 步骤 4 中的图像 2,2
    • Use a SIM tool to push pin fully through and out.
    • Repeat on the other side.
  5. JBL Everest Elite 300 Headband Cushion Replacement: 步骤 5 中的图像 1,2 JBL Everest Elite 300 Headband Cushion Replacement: 步骤 5 中的图像 2,2
    • Go along the edges with the pick, and pull up, taking off the band.
  6. JBL Everest Elite 300 Headband Cushion Replacement: 步骤 6 中的图像 1,3 JBL Everest Elite 300 Headband Cushion Replacement: 步骤 6 中的图像 2,3 JBL Everest Elite 300 Headband Cushion Replacement: 步骤 6 中的图像 3,3
    • After fully taking off the band, you are now ready to insert in the new band.
    • When placing in the new headband, line up the holes as shown in image 2.
    • The headband is difficult to replace, however after lining up the holes, the headband will snap into place. Push into the plastic and push away from you. A click will happen indicating it attatching.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 88
