跳转到主内容
JBL Everest Elite 300 Charging Port Replacement
你所需要的
  1. JBL Everest Elite 300 Charging Port Replacement, Speaker: 步骤 1 中的图像 1,1
    • Remove the ear pad with an opening pick.
  2. JBL Everest Elite 300 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Reveal the speaker.
  3. JBL Everest Elite 300 Charging Port Replacement: 步骤 3 中的图像 1,1
    • Remove the 4.5 mm screws using the Phillips #00 screwdriver.
  4. JBL Everest Elite 300 Charging Port Replacement: 步骤 4 中的图像 1,1
    • Pull apart the bronze speaker away from the headphones carefully to reveal the wiring.
    • Desolder the motherboard speaker connection.
  5. JBL Everest Elite 300 Charging Port Replacement, Charging port: 步骤 5 中的图像 1,1
    • Remove the .5mm screw on the headphone jack circuit board that is covering the charging port.
  6. JBL Everest Elite 300 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Remove the .5mm screw from the charging port circuit board.
结论
Gabe Clayton
于09/13/23注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 89
