跳转到主内容
JBL Clip 3 Speaker Housing Replacement
你所需要的
  1. JBL Clip 3 Speaker Housing Replacement, Speaker Grill: 步骤 1 中的图像 1,2 JBL Clip 3 Speaker Housing Replacement, Speaker Grill: 步骤 1 中的图像 2,2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Speaker Housing Replacement, Speaker Housing: 步骤 2 中的图像 1,2 JBL Clip 3 Speaker Housing Replacement, Speaker Housing: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Speaker Housing Replacement: 步骤 3 中的图像 1,1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Speaker Housing Replacement: 步骤 4 中的图像 1,2 JBL Clip 3 Speaker Housing Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
结论
3等其他人完成本指南。
Kyle Montague
于03/28/22注册
259 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 57
总计 1,340
