跳转到主内容
JBL Clip 3 Carabiner Clip Replacement
你所需要的
  1. JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: 步骤 1 中的图像 1,2 JBL Clip 3 Carabiner Clip Replacement, Speaker Grill: 步骤 1 中的图像 2,2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: 步骤 2 中的图像 1,2 JBL Clip 3 Carabiner Clip Replacement, Speaker Housing: 步骤 2 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Carabiner Clip Replacement: 步骤 3 中的图像 1,1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Carabiner Clip Replacement: 步骤 4 中的图像 1,2 JBL Clip 3 Carabiner Clip Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: 步骤 5 中的图像 1,2 JBL Clip 3 Carabiner Clip Replacement, Carabiner Clip: 步骤 5 中的图像 2,2
    • Lift the metal carabiner clip from the speaker housing.
    • They are not glued together and should separate easily.
    • There are alignment tabs on the clip so the whole assembly will only reassemble in one orientation.
结论
2等其他人完成本指南。
Tyler Molden
于03/28/22注册
492 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 的会员
UMASSD-PETERSEN-S22S1G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 47
过去 30 天: 175
总计 3,752
