跳转到主内容
JBL Clip 2 Speaker Replacement
你所需要的
  1. JBL Clip 2 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: 步骤 2 中的图像 1,1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: 步骤 3 中的图像 1,1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: 步骤 4 中的图像 1,1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
结论
4等其他人完成本指南。
Michael Hong
于02/01/17注册
1,014 声望
创作了5篇指南
团队
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 的会员
UWT-ROSE-W17S2G2
4 名成员
创作了7篇指南
6条评论
If no parts are required what are you replacing the speaker with?
Tom - 回复
Tom is right you know!
edward felix - 回复
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - 回复
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - 回复
Hi, where I can buy the speaker please? Thank you.
Govan - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 70
总计 6,326
