简介
If your JBL Clip 2's built in AUX cord is not playing music from your music device there may be an issue with the cord itself. The device will be taken apart and the audio AUX cord will be removed and replaced.
你所需要的
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
Disconnect the three solder points connecting the AUX cord to the motherboard.
Remove the AUX cord.
for the jbl clip 2 where do you buy the aux replacement cord?
have you found where it sells?
I used these guides to help me get the Clip 2 apart and found that my problem was a bad solder joint at the speaker connector. Apparently the manufacturer noticed it too because there was a (grease pencil) circle around the holes on the bottom side of the motherboard and their fix was to hot glue the connector to the board. I re-soldered the pins and it works perfectly.
3等其他人完成本指南。
