简介
The speakers are located behind the motherboard. Follow this guide to replace one or both broken speakers.
你所需要的
Make sure the device is powered off before you begin to disassemble the speaker.
Remove the trim from the speaker using a jimmy or metal spudger.
Using the PH1 screwdriver, remove the 9mm Phillips screw that connects the black tube to the device's interior.
14等其他人完成本指南。
12条评论
Donde encuentro las bocinas no sirven la que tiene
feliper233 - 回复
Donde puedo conseguir las bocinas?
feliper233 - 回复
Where can I get gthe replacement speaker?
where can i get replaicment speaker?
