跳转到主内容
JBL Charge Button Membrane Replacement
你所需要的
  1. JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: 步骤 1 中的图像 1,3 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: 步骤 1 中的图像 2,3 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: 步骤 1 中的图像 3,3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Button Membrane Replacement: 步骤 2 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 2 中的图像 2,2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Button Membrane Replacement: 步骤 3 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Button Membrane Replacement: 步骤 4 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 4 中的图像 2,2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Button Membrane Replacement: 步骤 5 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 5 中的图像 2,2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Button Membrane Replacement: 步骤 6 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 6 中的图像 2,2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Button Membrane Replacement: 步骤 7 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 7 中的图像 2,2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Button Membrane Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Button Membrane Replacement: 步骤 9 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 9 中的图像 2,2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Button Membrane Replacement: 步骤 10 中的图像 1,1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Button Membrane Replacement: 步骤 11 中的图像 1,2 JBL Charge Button Membrane Replacement: 步骤 11 中的图像 2,2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Button Membrane Replacement, Button Membrane: 步骤 12 中的图像 1,1
    • Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
  13. JBL Charge Button Membrane Replacement: 步骤 13 中的图像 1,1
    • Gently pull out the button membrane. You should not expect much resistance.
结论
4等其他人完成本指南。
Jake Bertholf
于04/01/15注册
366 声望
创作了2篇指南
团队
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 的会员
CPSU-LANCASTER-S15S12G1
5 名成员
创作了11篇指南
2条评论
conseguiste el boton de repuesto?
Mario A Vargas S - 回复
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
Joe Durand -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 9,516
