跳转到主内容
JBL Charge 4 Passive Bass Radiators Replacement
你所需要的
  1. JBL Charge 4 Passive Bass Radiators Replacement, Speaker Grill: 步骤 1 中的图像 1,1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Passive Bass Radiators Replacement: 步骤 2 中的图像 1,2 JBL Charge 4 Passive Bass Radiators Replacement: 步骤 2 中的图像 2,2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Passive Bass Radiators Replacement: 步骤 3 中的图像 1,1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: 步骤 4 中的图像 1,2 JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: 步骤 4 中的图像 2,2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Passive Bass Radiators Replacement: 步骤 5 中的图像 1,2 JBL Charge 4 Passive Bass Radiators Replacement: 步骤 5 中的图像 2,2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
结论
9等其他人完成本指南。
Zachary Colwell
于01/24/19注册
1,914 声望
创作了5篇指南
团队
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 的会员
CPSU-WHITE-W19S1G1
4 名成员
创作了26篇指南
5条评论
Exactly where are supposed to get parts for this, do you suppose !?
Yash Bhushan - 回复
It says it on the top of the introduction
Jacob Galeano Garcia -
Hi do you hany any suggestion on where to buy the passive radiators?
Epolu Isaac Tushabe - 回复
Were can i get the main cover from can you help please and the subwoofers
Nate Millette - 回复
Yo tengo la charge 4 y se me rompió uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
Reynaldo Ronquillo - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 69
总计 6,841
