跳转到主内容
JBL Charge 3 扬声器更换
你所需要的
  1. JBL Charge 3 扬声器更换, 前部面板: 步骤 1 中的图像 1,3 JBL Charge 3 扬声器更换, 前部面板: 步骤 1 中的图像 2,3 JBL Charge 3 扬声器更换, 前部面板: 步骤 1 中的图像 3,3
    • 将你的扬声器上下颠倒然后将塑料撬棍垂直塞入前部面板的缝隙中。
    • 慢慢向外拉动塑料撬棍来撬开固定它的四个卡扣。
    • 在四个边缘都重复这个步骤。
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - 回复
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - 回复
    There are two Phillips head screws to remove before prying the cover off
    jason - 回复
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - 回复
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - 回复
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - 回复
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - 回复
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - 回复
  2. JBL Charge 3 扬声器更换: 步骤 2 中的图像 1,1
    • 轻轻地从两侧拽开,并且从扬声器外壳移除。
    • 前部面板的内部有为了重新组装而必须与在扬声器外壳的销对应的洞。
    • 移除前部面板并不会影响设备的防水密封。然而,任何进一步的拆解都需要你移除防水密封和垫片。在这些被改动之后,你的设备可能不再防水。
    Include dissembling the plastic cover? cover?
    KanGoon - 回复
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Frank Puranik - 回复
    Very good guide! Pics and descriptions make this easy!
    John G Petko - 回复
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - 回复
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - 回复
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - 回复
  3. JBL Charge 3 扬声器更换, 扬声器: 步骤 3 中的图像 1,2 JBL Charge 3 扬声器更换, 扬声器: 步骤 3 中的图像 2,2
    • 移除在两个前置扬声器周围的八个10mm #1 十字螺丝。
    Die Frage : Ist ob man irgendwo Ersatz Lautsprecher bekommt ???
    nicowihnaleck - 回复
    Probier's mal hier, vergleiche aber ganz genau (Seriennummer GG…):
    https://ecommerce.mysav.eu/en/jbl/147-sp...
    VauWeh - 回复
  4. JBL Charge 3 扬声器更换: 步骤 4 中的图像 1,1
    • 轻轻地从外壳拉出一个扬声器。请小心因为它与主板线连接。
  5. JBL Charge 3 扬声器更换: 步骤 5 中的图像 1,3 JBL Charge 3 扬声器更换: 步骤 5 中的图像 2,3 JBL Charge 3 扬声器更换: 步骤 5 中的图像 3,3
    • 用#000 十字螺丝刀按一下扬声器接头的小金属盖,然后轻轻的将接头拉下。
    Where can l buy those speaker for replacing
    Terrence Terrence - 回复
    Somebody know where I can buy These speakers ?
    motje - 回复
    The speakers that is on my charge 3 is soldered on doesn’t have the clips in picture
    travenature - 回复
  6. JBL Charge 3 扬声器更换: 步骤 6 中的图像 1,1
    • 在第二个扬声器执行之前的步骤。
  7. JBL Charge 3 扬声器更换: 步骤 7 中的图像 1,2 JBL Charge 3 扬声器更换: 步骤 7 中的图像 2,2
    • 将捆好的主板与扬声器的接头用镊子夹住。轻轻的将接头拉出。
  8. JBL Charge 3 扬声器更换: 步骤 8 中的图像 1,1
    • 现在第二个扬声器已经与主板脱离,将扬声器和线从外壳中拉出。
    where can i buy these speaker,i need to replace the left side speaker because it was already damaged
    geoffrey mustar - 回复
结论
通过执行相反顺序的步骤来重新组装您的设备。
42等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Satyr正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Aidan Hays
于10/08/18注册
3,815 声望
创作了2篇指南
团队
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 的会员
CPSU-WHITE-F18S13G1
3 名成员
创作了26篇指南
31条评论
Where I can buy the same jbl speaker ?
Ekinox - 回复
I need to replace my JBL charge 3 speaker
Lara Esther -
Where can buy the small speakers? Helpp
Luis Cilia - 回复
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - 回复
where can i buy the replacement speakers?
Yhamani Pangarungan - 回复
Mine did not have the little clips in step 5. It was just soldered on. I ended up removing it from the other end. At the little white clip that goes in the motherboard (shown in step &) I was able to remove the pin. by pressing down on the top where you can see the silver.
Mike - 回复
It doesn’t seem possible to buy replacement speaker units.
dave - 回复
I see them on ebay, there are two designs. Btw, my speakers don't have clips, they are soldered on.
Erwin Johnson - 回复
i just completed this repair using generic replacement speakers from ali express item number 32829635211
mine were soldered on. i had to trim 4 orientation posts that prevent the factory speakers being installed rotated incorrectly, as these wouldn’t work with the new speakers. they sound OK, but have noticeably less bass than the OEM JBL drivers and can sound a little more tinny. there are also people doing it on ebay for 30$, but i am not in the USA so that was not convenient.
ivan@absolutehid
ivan - 回复
Where can I buy these same speakers
Silvester Whitehurst - 回复
San mkabili ng orig.na speaker ng jbl3?
rodolfom.afan - 回复
where I can buy these speakers. also need it for India region . but as I checked not able to buy it .
Prince Gupta - 回复
Contact JBL customer service if y3have or gen get the teveipt call them and then email pic8or the receipt ant the JBL Serial number by the speakers when the blabk jbl grill is off if less than 12 months old youll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for Charge3 is only $32.19 USD. Good luck.
David Lorince - 回复
Contact JBL customer service if you have a charge 3. get the customer service number, call them and or then just email description fate SN# and pic of the receipt and the JBL Serial number between the speakers when the black JBL grill is off, but only if its less than 12 months old then you’ll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for it is cheap only the JBL Charge3 is only $32.19 USD. Good luck.
David Lorince - 回复
If you can find a cheap replacement battery for $20 grab it cause its totally worth it if out in the wilderness it also acts as a cellphone charger.
David Lorince - 回复
Fyi upset neighbors since my left charge 3 is blown i decided it daisy chain 3 50 wayt pyle horn tweeters omg lets just day its about 500p% louder. Lol. Happy 4th of
David Lorince - 回复
Do you have a specific link for this OEM JBL charge 3 speaker replacement or are you just directing us to the JBL company where they currently want $35 + shipping on a single speaker unless the Charge 4 and Flip 4 lower these crazy prices. Has any one found a similar Charge 3 speaker replacement that’s louder and cheaper ???
David Lorince - 回复
For anyone that is wondering where to buy the speaker replacement, you can find it on all express just search up JBL charge 3 speaker replacement.
Armin Aghayan - 回复
Absolutely ridiculous how much replacement speakers are! I found some that “work” but they sound like crap…… Considering I have 4 Charge3’s and 1 Charge4, Harmon already has PLENTY of my $$!
Sheldon Abbey - 回复
JBL Charge 3 -
vorrei acquistare la coppia di casse uguale modello e dimensioni potreste fornirmi l’articolo a il link x ordinarli grazie
I would like to purchase the pair of speakers of the same model and size, could you provide me with the article at the link to order them, thank you
roberto - 回复
Ciao @flipok ! Maybe you can find some options in this Answer on our Forum: Where to buy replacement speakers for JBL Charge 3? Good luck!
Claire Miesch -
In accurate info unless they change how they put it together later down the road
travenature - 回复
good dayhouse pls where can i buy replacement speaker for jbl charge 3 and battery any body with information thanks
EMMANUEL JUNIOR - 回复
I've ordered one. I will update after installation is done.
Rich Buffetta - 回复
Simple install. Youll need a soldering iron, some solder and a smallish phillips. Works fine now for about 10 bucks from ali.
Rich Buffetta -
Amazon, JBL.Com, Ebay.. Search for OEM JBL Charge 3 replacement speaker. Very easy.
David Lorince - 回复
Original speaker parts can be obtained in the UK by contacting Multicare Electronics ( +441132791255 , info@multicare.org.uk ). I initially called the Harman support line (Harman is the umbrella company of JBL), who redirected me to Multicare who are their official repair/parts company in the UK. Multicare sent me a replacement speaker unit for about £20 (ex shipping), which I have now fitted and is working perfectly. Good experience and thanks for this iFixit guide!
nixrushperseus - 回复
I got my Charge 3 used, and apparently abused. Right speaker has pin holes in the cone; left speaker missing...
My question is why would anyone ground the + input to the speakers? Both are connected to the speaker inputs and also grounded to the speaker frame...
Thanks
Perry Thompson - 回复
添加评论
浏览统计数据:
过去 24 小时: 38
过去 7 天: 218
过去 30 天: 953
总计 87,765
