跳转到主内容
JBL Charge 3 Passive Radiators Replacement
你所需要的
  1. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: 步骤 1 中的图像 1,3 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: 步骤 1 中的图像 2,3 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: 步骤 1 中的图像 3,3
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  2. JBL Charge 3 Passive Radiators Replacement: 步骤 2 中的图像 1,2 JBL Charge 3 Passive Radiators Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tools underneath both tabs.
  3. JBL Charge 3 Passive Radiators Replacement: 步骤 3 中的图像 1,1
    • Twist and pull open the passive radiator. The left radiator twists off counterclockwise; the right clockwise.
  4. JBL Charge 3 Passive Radiators Replacement: 步骤 4 中的图像 1,2 JBL Charge 3 Passive Radiators Replacement: 步骤 4 中的图像 2,2
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
结论
5等其他人完成本指南。
Jack Ng
于10/08/18注册
2,140 声望
创作了4篇指南
团队
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Cal Poly, Team S1-G6, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G6
4 名成员
创作了27篇指南
4条评论
i have a different model of the charge 3 it doesnt have screws but its hard to take out
Water Bass Tester (Water BT) - 回复
mine has screws and was also hard to pull with one hand
Carbon cookie -
Ich finde den Passivenstrahler nicht als Ersatzteil im Internet. Kann wer da helfen?
Sebastix01 _ - 回复
I have two of the same without screws, the process is precisely the same. Just need to do it a little bit harder
Francisco Sarmento - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 41
过去 30 天: 155
总计 14,151
