跳转到主内容
JBL Charge 3 Passive Radiators Replacement
你所需要的
  1. JBL Charge 3 Passive Radiators Replacement, Passive Radiators: 步骤 1 中的图像 1,3 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: 步骤 1 中的图像 2,3 JBL Charge 3 Passive Radiators Replacement, Passive Radiators: 步骤 1 中的图像 3,3
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
    If your Charge 3 doesn’t look like the above. Do not do this step YET. Go directly to Step 7 removal of the battery. By doing the battery first it will tell you which radiator to remove and thus no need to remove both.
    NOTE:
    On a newer version of the Charge 3 this image will be very different. you will not find a screw. You will also notice that there are two tabs that if slightly lifted while rotating the radiator counter clockwise the radiator is easily removed. There is also no foam or breakable seal on the newer Charge 3.
    john Ramirez - 回复
  2. JBL Charge 3 Passive Radiators Replacement: 步骤 2 中的图像 1,2 JBL Charge 3 Passive Radiators Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tools underneath both tabs.
    Beim Modell 2016 geht es noch einfacher: Da ist es ein Bajonett-Verschluss (und nur 1 Schraube im vorigen Schritt). Man muss die Abdeckung nur ein paar Grad gegen den Uhrzeigersinn drehen und kann sie dann einfach abziehen. Schritt 5 und 6 entfallen.
    Franz - 回复
    I believe this is unnecessary, just turn the passive radiator counter clockwise and pull outward. I tried to use the pry tool and broke a plastic tab.
    Frank Krantz - 回复
    Tip— when you get to this part lightly tap the edge of the speaker on a hard surface— like you’re tapping a jar before opening it.
    maxthibodeaux - 回复
    Muchas gracias a todos, me dieron cada uno la guía perfecta.
    Rafael de la Torre Perez - 回复
    My charge 3 had less screws but the process was the same. Thanks for the instructions!
    Ryan Parker - 回复
  3. JBL Charge 3 Passive Radiators Replacement: 步骤 3 中的图像 1,1
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
    attention assez dur a enlever, le mien dur à tourner
    Walter Rousseau - 回复
  4. JBL Charge 3 Passive Radiators Replacement: 步骤 4 中的图像 1,2 JBL Charge 3 Passive Radiators Replacement: 步骤 4 中的图像 2,2
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
    right or left…. depends on how you view the Charge 3 i guess. No need to remove both radiators for a newer Charge 3. You can remove the battery cover first…find out what side the battery wires exit the battery compartment and then remove the radiator associated with that same side.
    john Ramirez - 回复
    Anybody else have major problems trying to twist the radiator back into position after replacing the battery? I’m having trouble getting the screw holes to line up again on the right radiator.
    Chapman Steamer 1 - 回复
    To twist back I used saliva so it will slide easier against the rubber
    Jaakob Wolff - 回复
结论
5等其他人完成本指南。
Jack Ng
于10/08/18注册
2,228 声望
创作了4篇指南
团队
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Cal Poly, Team S1-G6, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G6
4 名成员
创作了27篇指南
4条评论
i have a different model of the charge 3 it doesnt have screws but its hard to take out
Water Bass Tester (Water BT) - 回复
mine has screws and was also hard to pull with one hand
Carbon cookie -
Ich finde den Passivenstrahler nicht als Ersatzteil im Internet. Kann wer da helfen?
Sebastix01 _ - 回复
I have two of the same without screws, the process is precisely the same. Just need to do it a little bit harder
Francisco Sarmento - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 34
过去 30 天: 129
总计 15,445
