跳转到主内容
JBL Charge 3 Front Cover Replacement
你所需要的
  1. JBL Charge 3 Front Cover Replacement, Front Cover: 步骤 1 中的图像 1,3 JBL Charge 3 Front Cover Replacement, Front Cover: 步骤 1 中的图像 2,3 JBL Charge 3 Front Cover Replacement, Front Cover: 步骤 1 中的图像 3,3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Front Cover Replacement: 步骤 2 中的图像 1,1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
结论
6等其他人完成本指南。
Aidan Hays
于10/08/18注册
3,815 声望
创作了2篇指南
团队
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 的会员
CPSU-WHITE-F18S13G1
3 名成员
创作了26篇指南
2条评论
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - 回复
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 88
总计 9,016
