跳转到主内容
JBL Charge 3 Battery Replacement
你所需要的
  1. JBL Charge 3 Battery Replacement, Front Cover: 步骤 1 中的图像 1,3 JBL Charge 3 Battery Replacement, Front Cover: 步骤 1 中的图像 2,3 JBL Charge 3 Battery Replacement, Front Cover: 步骤 1 中的图像 3,3
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
  2. JBL Charge 3 Battery Replacement: 步骤 2 中的图像 1,1
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
  3. JBL Charge 3 Battery Replacement, Passive Radiators: 步骤 3 中的图像 1,3 JBL Charge 3 Battery Replacement, Passive Radiators: 步骤 3 中的图像 2,3 JBL Charge 3 Battery Replacement, Passive Radiators: 步骤 3 中的图像 3,3
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  4. JBL Charge 3 Battery Replacement: 步骤 4 中的图像 1,2 JBL Charge 3 Battery Replacement: 步骤 4 中的图像 2,2
    • Insert the plastic opening tools underneath both tabs.
  5. JBL Charge 3 Battery Replacement: 步骤 5 中的图像 1,1
    • Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
  6. JBL Charge 3 Battery Replacement: 步骤 6 中的图像 1,2 JBL Charge 3 Battery Replacement: 步骤 6 中的图像 2,2
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
  7. JBL Charge 3 Battery Replacement, Battery: 步骤 7 中的图像 1,3 JBL Charge 3 Battery Replacement, Battery: 步骤 7 中的图像 2,3 JBL Charge 3 Battery Replacement, Battery: 步骤 7 中的图像 3,3
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
  8. JBL Charge 3 Battery Replacement: 步骤 8 中的图像 1,3 JBL Charge 3 Battery Replacement: 步骤 8 中的图像 2,3 JBL Charge 3 Battery Replacement: 步骤 8 中的图像 3,3
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
  9. JBL Charge 3 Battery Replacement: 步骤 9 中的图像 1,2 JBL Charge 3 Battery Replacement: 步骤 9 中的图像 2,2
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
  10. JBL Charge 3 Battery Replacement: 步骤 10 中的图像 1,1
    • Pull the battery and battery cable out from their housing.
结论
132等其他人完成本指南。
Jack Ng
于10/08/18注册
2,140 声望
创作了4篇指南
团队
Cal Poly, Team S1-G6, Zimmerman Spring 2020 Cal Poly, Team S1-G6, Zimmerman Spring 2020 的会员
CPSU-ZIMMERMAN-S20S1G6
4 名成员
创作了27篇指南
32条评论
you legend. thank you so much! i was worried it was a seal unit!
Anthony Hilfischer - 回复
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Tomas Opmann - 回复
thank you so much :D
punkzmarc - 回复
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
Dom Heizmann - 回复
I saw one on youtube taking the one from the old battery and putting it on the new one
Dominik Spreuer -
添加评论
浏览统计数据:
过去 24 小时: 79
过去 7 天: 646
过去 30 天: 2,888
总计 213,040
