跳转到主内容
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
你所需要的
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: 步骤 1 中的图像 1,1
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 2 中的图像 1,2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 2 中的图像 2,2
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 3 中的图像 1,1
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 4 中的图像 1,2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 4 中的图像 2,2
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 5 中的图像 1,1
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 6 中的图像 1,2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 步骤 6 中的图像 2,2
    • Slide the ribbon gently out of the connector.
结论
17等其他人完成本指南。
John Reynolds
于10/16/15注册
3,158 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G1
4 名成员
创作了12篇指南
15条评论
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - 回复
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - 回复
I think it is not normal, if you can find it please contact me! Thanks
Clash Ofclans - 回复
I also need to replace my usb connector, has anyone found out where to get one?
Rick - 回复
need the micro-usb aswell
hellgrenmicke - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 74
总计 27,012
