跳转到主内容
JBL Charge 2 Plus Battery Replacement
你所需要的
  1. JBL Charge 2 Plus Battery Replacement, Passive Radiators: 步骤 1 中的图像 1,2 JBL Charge 2 Plus Battery Replacement, Passive Radiators: 步骤 1 中的图像 2,2
    • Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
    • Follow the previous instruction to remove the back grille.
  2. JBL Charge 2 Plus Battery Replacement: 步骤 2 中的图像 1,3 JBL Charge 2 Plus Battery Replacement: 步骤 2 中的图像 2,3 JBL Charge 2 Plus Battery Replacement: 步骤 2 中的图像 3,3
    • Unscrew the two .5 mm screws that hold the sub woofer in place.
    • Repeat the last step for the two screws on the back side.
  3. JBL Charge 2 Plus Battery Replacement: 步骤 3 中的图像 1,2 JBL Charge 2 Plus Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the four screws that hold the passive radiator in place
  4. JBL Charge 2 Plus Battery Replacement: 步骤 4 中的图像 1,1
    • Pop the Passive Radiator off.
  5. JBL Charge 2 Plus Battery Replacement: 步骤 5 中的图像 1,3 JBL Charge 2 Plus Battery Replacement: 步骤 5 中的图像 2,3 JBL Charge 2 Plus Battery Replacement: 步骤 5 中的图像 3,3
    • Repeat Step 2, 3 and 4 for the other passive radiator.
  6. JBL Charge 2 Plus Battery Replacement, Battery: 步骤 6 中的图像 1,2 JBL Charge 2 Plus Battery Replacement, Battery: 步骤 6 中的图像 2,2
    • Remove the battery wire from the circuit board by pulling it out gently on the side closest to the LCD light.
  7. JBL Charge 2 Plus Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the 6 screws that hold the white cover in place.
  8. JBL Charge 2 Plus Battery Replacement: 步骤 8 中的图像 1,2 JBL Charge 2 Plus Battery Replacement: 步骤 8 中的图像 2,2
    • Use the plastic opening tool to remove the battery.
结论
72等其他人完成本指南。
John Reynolds
于10/16/15注册
3,134 声望
创作了4篇指南
团队
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 的会员
UMASSD-CATANIA-F15S4G1
4 名成员
创作了12篇指南
37条评论
Great guide but where to source a battery for a JBL charge 2.
Mine failed, complained to Harman and they sent a new one and didn't want the old one so have a spare I'd like to get working.
Thanks in advance
Rob grist - 回复
Had my speaker for a month. It won't charge. Why did it only last a month and I have to get a new one? I'm not satisfied with the speaker for the price that I paid.
Jeanette dagastine - 回复
When I charge my jbl the light in tge power button turns on but when I press it the device does not respond. Please help me...
Tibetan Stoner - 回复
Try disconnecting the battery and plugging it in again.
MarelyOscar -
I just had the same problem, the on/off led got stuck and couldn't get any sound or operation from any button. After different attempts a simultaneous pressing of the Phone together with the - and the + button brought my Charge2 to life again.
Javier G. Valdivia -
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 69
过去 30 天: 381
总计 131,911
