你所需要的
拧下将低音扬声器固定到位的两颗.5 mm螺丝。
对背面的两个螺丝重复最后一步。
no 5mm screws going into the radiator on my device
I had the same issue. I managed to unplug the battery cable after removing the right front speaker
I have the charge 2 + and only needed to take off the back grill. Then removed 6 smaller screws from a black rectangular cover, which turns out to be the battery cover! Then unplugged the battery and removed it. Many less steps than described in the steps here. Note I did NOT have to remove either round end.
I did the same thing! Everybody should read your comment before attempting this whole process described below.
You ONLY have to remove the back grille, and you will see the battery cover. Unscrew the small philips screws from the battery cover, then the whole battery cover can be removed.
nus.czm -
The other comments are misleading. Yes, you can see the battery if you remove the white cover, but if you attemp to remove it you will damage the cables. You first need to unplug it by removing the end on the side of the LED as explained on the next steps. Only the side closer to the LED is necessary though.
拆下将被动散热器固定到位的四颗螺丝。
also there are no screws that hold the passive radiator in place.
The screws are under the plastic cover you unscrewed before. You can pop it of with a flat screwdriver or your nails
对其他被动散热器重复步骤2,3和4。
No, you only have to disconnect the right passive radiator to get to the battery and plug it.
True. This step is unnecessary. You only need to pop the radiator under which the cables of the battery go.
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
7等其他人完成本指南。
由衷感谢以下译者:
100%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
When charging my charge 2+ 4 LED lights are blowing but 5th one is not blowing , 5th one blows when Bluetooth is on that is when speaker is on . I don't know what to do please help mail at jomonjohny140898@gmail.com
Test because my last comment disappeared.
Debra Bainum - 回复
You might ONLY need to remove the back grille. Read the comments on the next step.
nus.czm - 回复
Agree with comments above. All I had to do was remove the back grille to get to the plastic battery cover similar to comment above.
Tim Pipkorn - 回复
Danke, das hat mir weitergeholfen.
Ganz herzlichen Dank
Michael Pauw 04.08.2021
Michael Pauw - 回复
