跳转到主内容
JBL Charge 2 Motherboard Replacement
你所需要的
  1. JBL Charge 2 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Motherboard Replacement: 步骤 2 中的图像 1,2 JBL Charge 2 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Motherboard Replacement: 步骤 3 中的图像 1,2 JBL Charge 2 Motherboard Replacement: 步骤 3 中的图像 2,2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Motherboard Replacement: 步骤 4 中的图像 1,2 JBL Charge 2 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Motherboard Replacement: 步骤 6 中的图像 1,3 JBL Charge 2 Motherboard Replacement: 步骤 6 中的图像 2,3 JBL Charge 2 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Motherboard Replacement, Speakers: 步骤 7 中的图像 1,1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
  10. JBL Charge 2 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Use a spudger to disconnect the gold antenna connector from the main circuit board.
  11. JBL Charge 2 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Disconnect the microphone connector using the plastic opening tool.
  12. JBL Charge 2 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Use a plastic opening tool to disconnect the 3.5 mm headphone connector.
  13. JBL Charge 2 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Disconnect micro-b connector with a plastic opening tool.
  14. JBL Charge 2 Motherboard Replacement: 步骤 14 中的图像 1,1
    • Remove the connector to the USB connector using a plastic opening tool.
  15. JBL Charge 2 Motherboard Replacement: 步骤 15 中的图像 1,1
    • Remove the speaker wires from the control panel by prying off with a plastic opening tool.
  16. JBL Charge 2 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Next, disconnect the control-panel ribbon by prying out the grey plastic tab using a plastic opening tool. The ribbon should freely come out afterwards.
  17. JBL Charge 2 Motherboard Replacement: 步骤 17 中的图像 1,3 JBL Charge 2 Motherboard Replacement: 步骤 17 中的图像 2,3 JBL Charge 2 Motherboard Replacement: 步骤 17 中的图像 3,3
    • Caution: Touching the capacitors will short out the circuit board. Push on the end of the circuit board and carefully keep thumbs on foam insulation on ends of board.
    • Remove the motherboard from the device.
结论
5等其他人完成本指南。
Mauzor Ilonzo
于09/26/17注册
495 声望
创作了3篇指南
团队
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G4
4 名成员
创作了8篇指南
2条评论
Guten Tag
Vielen Dank für die prima Anleitung!
Ich habe den Fehler bei meinem Charge 2+ gefunden. Das Bauteil mit der 100 drauf ist außen mehrfach gerissen. Was ist das für ein Bauteil und kann ich das bestellen?
Liebe Grüße
Stefan
Stefan Erb - 回复
Hello i have a problem with component 100 but i don't now what is ? someone can help me thanks and from were can i order ?
naskicha_94 - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 60
总计 8,334
