跳转到主内容
JBL Charge 2 Battery Replacement
你所需要的
  1. JBL Charge 2 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Battery Replacement: 步骤 2 中的图像 1,2 JBL Charge 2 Battery Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Battery Replacement: 步骤 3 中的图像 1,2 JBL Charge 2 Battery Replacement: 步骤 3 中的图像 2,2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Battery Replacement: 步骤 4 中的图像 1,2 JBL Charge 2 Battery Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Battery Replacement: 步骤 6 中的图像 1,3 JBL Charge 2 Battery Replacement: 步骤 6 中的图像 2,3 JBL Charge 2 Battery Replacement: 步骤 6 中的图像 3,3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
结论
10等其他人完成本指南。
Mauzor Ilonzo
于09/26/17注册
495 声望
创作了3篇指南
团队
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G4
4 名成员
创作了8篇指南
3条评论
Thanks for the manual! Easy repair this way.
Jeroen Cox - 回复
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Rogelio Fernandez - 回复
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
Vasudev Chiratla -
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 69
过去 30 天: 287
总计 20,170
