跳转到主内容
Ivation IVWPDC20Y Buttons Replacement
你所需要的
  1. Ivation IVWPDC20Y Buttons Replacement, Buttons: 步骤 1 中的图像 1,1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Buttons Replacement: 步骤 2 中的图像 1,1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Buttons Replacement: 步骤 3 中的图像 1,1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
  4. Ivation IVWPDC20Y Buttons Replacement: 步骤 4 中的图像 1,1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Buttons Replacement: 步骤 5 中的图像 1,1
    • Pry off back outer casing using the black spudger or the blue prying tools
  6. Ivation IVWPDC20Y Buttons Replacement: 步骤 6 中的图像 1,1
  7. Ivation IVWPDC20Y Buttons Replacement: 步骤 7 中的图像 1,1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
  8. Ivation IVWPDC20Y Buttons Replacement: 步骤 8 中的图像 1,1
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
  9. Ivation IVWPDC20Y Buttons Replacement: 步骤 9 中的图像 1,1
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
  10. Ivation IVWPDC20Y Buttons Replacement: 步骤 10 中的图像 1,1
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
  11. Ivation IVWPDC20Y Buttons Replacement: 步骤 11 中的图像 1,1
    • Use the metal prying tool to lift off the cover of the buttons
  12. Ivation IVWPDC20Y Buttons Replacement: 步骤 12 中的图像 1,1
    • Use the PH00 bit to remove the four screws on the metal plate around the buttons
  13. Ivation IVWPDC20Y Buttons Replacement: 步骤 13 中的图像 1,1
    • Finally, use the plastic spudger to push buttons out, and then replace them
结论
另外一个人完成了本指南。
Alex
于02/08/16注册
228 声望
创作了2篇指南
团队
USF Tampa, Team 6-6, Eyestone Spring 2016 USF Tampa, Team 6-6, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G6
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 383
