跳转到主内容
Ion Air Pro Record and Stop Switch Replacement
你所需要的
  1. Ion Air Pro Record and Stop Switch Replacement, Record and Stop Switch: 步骤 1 中的图像 1,1
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Ion Air Pro Record and Stop Switch Replacement: 步骤 2 中的图像 1,2 Ion Air Pro Record and Stop Switch Replacement: 步骤 2 中的图像 2,2
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Ion Air Pro Record and Stop Switch Replacement: 步骤 3 中的图像 1,1
    • Remove black aluminum casing as shown.
  4. Ion Air Pro Record and Stop Switch Replacement: 步骤 4 中的图像 1,1
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  5. Ion Air Pro Record and Stop Switch Replacement: 步骤 5 中的图像 1,1
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
结论
另外一个人完成了本指南。
团队
UW Stout, Team S6-G2, Ogden Fall 2018 UW Stout, Team S6-G2, Ogden Fall 2018 的会员
UWSTOUT-OGDEN-F18S6G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 15
总计 369
