当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
Move down the same side and push in the plastic tab.
Move to the front right side and once again push in the plastic tab.
There is not a fourth tab to push in after this one.
Grab the cover by the front side and pull upwards.
You might encounter some resistance. Pull firmly, but don't yank it.
Tilt the front case down until the pegs detach from the bottom of the case.
Lift up and outward.
The motherboard will be loose at this point.
Unhook the two springs from the front plastic hooks.
The black side rails of the reader should easily slide forward and off.
There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
The tab does not come completely out, it only slides up slightly, so don't rip it out!
Grab the reader by its sides and gently pull it upward.
There are two wires still connected to the bottom of the reader that haven't been detached.
Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
Lift the reader up and out from the device.
Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
Gently lift the motherboard and back case out from the bottom case.
取消:我没有完成这个指南。
与3其他贡献者
于10/05/10注册
288 声望
创作了2篇指南
徽章: 11
+ 8更多徽章
CPSU-AMIDO-F10S7G53
4 名成员
创作了6篇指南
how to fix the motherboard if booth leds stay lit when powering up?
ACIDGREEN TECHNO - 2020年3月3日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 3,426
