跳转到主内容
配件
没有特定配件。
  1. Push in the plastic tab that can be seen through cracks in the front left corner using a spudger. Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Move down the same side and push in the plastic tab.
    • Move down the same side and push in the plastic tab.
  3. Move to the front right side and once again push in the plastic tab.
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Grab the cover by the front side and pull upwards. You might encounter some resistance. Pull firmly, but don't yank it.
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  6. Tilt the front case down until the pegs detach from the bottom of the case. Lift up and outward.
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  7. Unhook the two springs from the front plastic hooks. The black side rails of the reader should easily slide forward and off.
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  8. There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  9. Grab the reader by its sides and gently pull it upward. There are two wires still connected to the bottom of the reader that haven't been detached.
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  10. Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  11. Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you. Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  12. Lift the reader up and out from the device.
    • Lift the reader up and out from the device.
结论
4等其他人完成本指南。
Ezery Kennedy
于2010年10月05日注册
207 信誉积分
创作了2篇指南
团队
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G53
4 名成员
创作了3篇指南
Great guide exactly what I was looking for.
Jim Schmidt - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 4
过去的30天: 18
总计 4,301
