跳转到主内容
Iomega Z100S2 Disk Reader Replacement
你所需要的
  1. Iomega Z100S2 Disk Reader Replacement, Case: 步骤 1 中的图像 1,2 Iomega Z100S2 Disk Reader Replacement, Case: 步骤 1 中的图像 2,2
    • Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
  2. Iomega Z100S2 Disk Reader Replacement: 步骤 2 中的图像 1,1
    • Move down the same side and push in the plastic tab.
  3. Iomega Z100S2 Disk Reader Replacement: 步骤 3 中的图像 1,1
    • Move to the front right side and once again push in the plastic tab.
    • There is not a fourth tab to push in after this one.
  4. Iomega Z100S2 Disk Reader Replacement: 步骤 4 中的图像 1,2 Iomega Z100S2 Disk Reader Replacement: 步骤 4 中的图像 2,2
    • Grab the cover by the front side and pull upwards.
    • You might encounter some resistance. Pull firmly, but don't yank it.
  5. Iomega Z100S2 Disk Reader Replacement: 步骤 5 中的图像 1,2 Iomega Z100S2 Disk Reader Replacement: 步骤 5 中的图像 2,2
    • Tilt the front case down until the pegs detach from the bottom of the case.
    • Lift up and outward.
    • The motherboard will be loose at this point.
  6. Iomega Z100S2 Disk Reader Replacement, Disk Reader: 步骤 6 中的图像 1,2 Iomega Z100S2 Disk Reader Replacement, Disk Reader: 步骤 6 中的图像 2,2
    • Unhook the two springs from the front plastic hooks.
    • The black side rails of the reader should easily slide forward and off.
  7. Iomega Z100S2 Disk Reader Replacement: 步骤 7 中的图像 1,1
    • There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
    • The tab does not come completely out, it only slides up slightly, so don't rip it out!
  8. Iomega Z100S2 Disk Reader Replacement: 步骤 8 中的图像 1,2 Iomega Z100S2 Disk Reader Replacement: 步骤 8 中的图像 2,2
    • Grab the reader by its sides and gently pull it upward.
    • There are two wires still connected to the bottom of the reader that haven't been detached.
  9. Iomega Z100S2 Disk Reader Replacement: 步骤 9 中的图像 1,1
    • Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
  10. Iomega Z100S2 Disk Reader Replacement: 步骤 10 中的图像 1,2 Iomega Z100S2 Disk Reader Replacement: 步骤 10 中的图像 2,2
    • Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
  11. Iomega Z100S2 Disk Reader Replacement: 步骤 11 中的图像 1,1
    • Lift the reader up and out from the device.
结论
5等其他人完成本指南。
Ezery Kennedy
于10/05/10注册
288 声望
创作了2篇指南
团队
Cal Poly, Team 7-53, Amido Fall 2010 Cal Poly, Team 7-53, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G53
4 名成员
创作了6篇指南
2条评论
Great guide exactly what I was looking for.
Jim Schmidt - 回复
Zip disks were awesome, and they still are they fit that niche between needing something small in capacity but not large enough for a USB flash drive.
Trevor Rawlinson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 6,089
