跳转到主内容
Intertek 20006 Fan Replacement
你所需要的
  1. Intertek 20006 Fan Replacement, Fan: 步骤 1 中的图像 1,2 Intertek 20006 Fan Replacement, Fan: 步骤 1 中的图像 2,2
    • Turn off the air humidifier using the 0/1 switch at the bottom edge of back side.
    • Hold the top-back of the air humidifier and remove the upper part from the lower part.
    • Remove water from the water chamber and wipe it.
  2. Intertek 20006 Fan Replacement: 步骤 2 中的图像 1,3 Intertek 20006 Fan Replacement: 步骤 2 中的图像 2,3 Intertek 20006 Fan Replacement: 步骤 2 中的图像 3,3
    • Flip the humidifier so that the bottom is facing upwards.
    • Use a Phillips # 2 screwdriver to remove four 13 mm screws from the bottom cover hole.
    • Remove the bottom cover to access the fan and other parts of the humidifier.
  3. Intertek 20006 Fan Replacement: 步骤 3 中的图像 1,2 Intertek 20006 Fan Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove four 30 mm screws from the fan.
    • Remove the fan from its place and keep it close to its power connector.
  4. Intertek 20006 Fan Replacement: 步骤 4 中的图像 1,2 Intertek 20006 Fan Replacement: 步骤 4 中的图像 2,2
    • Using a spudger, straighten all three metal latches.
    • Hold both edges of the metal cover with your finger and pull upward to take it out from its position.
    • Metal cover edges are very sharp. Watch your finger when holding the metal cover.
  5. Intertek 20006 Fan Replacement: 步骤 5 中的图像 1,3 Intertek 20006 Fan Replacement: 步骤 5 中的图像 2,3 Intertek 20006 Fan Replacement: 步骤 5 中的图像 3,3
    • Pull out the power connector of the fan from its port.
    • Use a wire cutter to cut the tie rope around the wires.
    • When cutting the tie rope, take care to avoid cutting any cables.
    • Remove the fan from the humidifier.
    • Plug in the new fan's power connector.
    • Tie all cables together using a twist tie.
  6. Intertek 20006 Fan Replacement: 步骤 6 中的图像 1,3 Intertek 20006 Fan Replacement: 步骤 6 中的图像 2,3 Intertek 20006 Fan Replacement: 步骤 6 中的图像 3,3
    • Attach the metal cover where it was before.
    • Bend the latches halfway down using a spudger to secure the metal cover.
  7. Intertek 20006 Fan Replacement: 步骤 7 中的图像 1,1
    • Secure the new fan with the four 30 mm screws using a Phillips #2 screwdriver.
  8. Intertek 20006 Fan Replacement: 步骤 8 中的图像 1,2 Intertek 20006 Fan Replacement: 步骤 8 中的图像 2,2
    • Put the bottom cover back in place.
    • Secure the bottom cover with the four 13 mm screws using a Phillips #2 screwdriver.
    • Flip the humidifier right-side up, and attach the upper part
终点
另外一个人完成了本指南。
[deleted]
于05/08/20注册
184 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 882
